Old 05-23-2009, 11:46 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default T-56 fitment question?
I'm looking to buy a used t-56 tranny out of a used 2002 corvette but i don't know if it will fit up to my 350 small block and if not is there any mods i can do?
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 05-24-2009, 12:45 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
T56 out of a Corvette isn't a good idea. It has no tailshaft housing and will need a fair amount of work to make usable.
Old 05-24-2009, 06:30 AM
Yea dont buy the Corvette T56 as it is a transaxle/rearmounted transmission. Not sure what you'd have to do to make it work. You can get a LT1 style T56 from Fbody or maybe earlier corvettes (92-96). You can also use the fbody/gto LS1 T56 but it requires an adaptor to make it fit on a reg small block chevy.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 05-24-2009, 11:37 AM
jcal87's Avatar
is there any t-56 that i cant fit up to a standard 350 and then fit up to an ls series later on if i upgrade?
1968 Camaro Blue
Texas A&M Alumni
Old 05-24-2009, 01:52 PM
Mkelcy's Avatar
Originally Posted by jcal87 View Post
is there any t-56 that i can fit up to a standard 350 and then fit up to an ls series later on if i upgrade?
LS1 T56, using standard Chevy bellhousing and McLeod adapter plate for now, LS1 bellhousing (or equivalent) when you make the switch to LS1.
Do some reading here, it might help: http://www.camaros.net/forums/showthread.php?t=98387
Old 05-26-2009, 08:49 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
^^what he said. I followed his notes and now have an LS1-sourced T56 behind my 350 SBC in my 77 Z28. McLeod adapter, extended pilot bushing, shorter driveshaft were needed. I modified my stock crossmember as well.
Scott from NJ
