Old 06-21-2009, 10:11 AM
g356gear's Avatar
g356gear g356gear is offline
Default 69 camaro - damaged main undercar brake line
Does anyone know if there is a replacement brake hard line available that runs under the drivers side body of the car? Mine is damaged and has a pretty good restriction where it has been crimped. I would like to get as close to OEM as possible. Any ideas?
Old 06-21-2009, 10:22 AM
DRJDVM's '69's Avatar
Yes....try Inline Tube or Classic Tube... there are some others too....or you can order them from Year One, Classic Industries, Ricks 1st Gen and some others....
Old 06-21-2009, 11:40 AM
That front to rear brake line is sold in one piece and 2 piece versions. Be sure to get a one piece version even if you have the 2 piece version since your going 4 wheels disc barkes. Try any Camaro restoration parts vendor you like.
Frank Serafine
Old 06-21-2009, 02:35 PM
g356gear's Avatar
Thanks Frank, any reason to go 1 piece? I do have a 2 piece on my car. There is a joiner block under the drivers seat.
Old 06-21-2009, 04:17 PM
Apogee Apogee is offline
That "joiner block" is probably a residual pressure valve that you will not need in a 4-wheel disc system, hence the recommendation to switch over to a 1-piece line. You can go either way though and just gut the residual pressure valve if you want to keep it in the system if or when you convert the rear to discs.
Tobin
KORE3
www.kore3.com
Old 06-21-2009, 07:20 PM
g356gear's Avatar
Tobin
KORE3
Thanks Apogee, I just finished the install on the Wilwood rear discs.
My other question is what to do with the connection from the hard line where it ends on the rear seat backing wall. In stock form it joins to a soft line, then to a splitter block mounted on top of the differential and then off to each drum brake. I have a shop that made me custom length lines for my Wilwood fronts and I am thinking about having a custom line made with a built in "T". The line would be made of plastic coated braided line that is DOT certified. Any thoughts on whether replacing the hard lines on the differential with a braided line would be a problem?
