Closed Thread
Old 05-13-2010, 04:38 PM
camaro73 camaro73 is offline
Default 1973 Z28 Camaro
I am selling my 1973 z28 Camaro. Very clean and laser straight.
400 4 bolt main
.40 over
350 steel crank
GM polished rods
10.1 Compression
280 comp cam
AFR aluminum heads 195
Hooker Jet Hot coated headers
Flow master exhaust
Roller rockers
650 Demon carb
Edelbrock RPM airgap manifold
TCI starter
Billet steel flywheel
Be-cool aluminum radiator
Dual 13’ fans
6 Speed Richmond transmission
Long shifter
Dennys Aluminum 3.5” drive shaft
12 bolt 3.31 gears
Superior axle
4 wheel disc brakes
Drilled / Slotted performance rotors.
Wilwood up front GM in back
Stainless steel brake line.
B body spindles
Close ratio steering box
Centerline starlite wheels
275/40/18 0n rear
255/45/17 up front
Falken Performance tires
Hotchkis 2” drop in front with sway bar.
Detroit speed rear 2’ drop springs in back
Urethane bushings
All new GM glass
$26000.00
located in Wisconsin
920-427-1373
Old 05-13-2010, 05:52 PM
Beegs's Avatar
Beegs Beegs is offline
Original body panels? Any interior pics?
Bryan
Old 05-13-2010, 07:00 PM
Default 1973 Z28
Bryan
I sent you a PM.
Old 05-14-2010, 07:33 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Nice looking car. Looks pretty clean
GOOD LUCK!
Old 05-16-2010, 07:30 AM
68/Camaro's Avatar
68/Camaro 68/Camaro is offline
Nice 2nd Gen! Good Luck with the Sale!!
Bill Panouses
Evade Camaro http://www.facebook.com/pages/Evade-...71454739554636
www.evadecamaro.com
Old 05-16-2010, 05:50 PM
damannhw's Avatar
damannhw damannhw is offline
Great looking car. What color is that ? Also interested in more info on body panels, original or not ?
Closed Thread
