Old 09-07-2009, 12:26 AM
clay69camaro's Avatar
clay69camaro clay69camaro is offline
Default sheet metal tool?
I'm looking to make some cuts to my floor boards and replace them. All I have is an angle grinder and would like to make a precise cut without all the sparks. What is the tool of choice I need for this job.... and for now I won't be able to purchase a plasma cutter as nice as that would be it's a little out of my budget
I would ideally like to keep this tool for future jobs like my quarters and roof and trunk, and... lots of sheet metal needs to be replaced
Thanks everyone
Old 09-07-2009, 08:16 AM
DRJDVM's '69's Avatar
Well if you want NO sparks an air saw is about all I can think of..
Something like this...
http://www.sears.com/shc/s/p_10153_1...eyword=air+saw
A metal shear wont really work very well, but I suppose you could try..
http://www.sears.com/shc/s/p_10153_1...rd=metal+shear
I use a cut off wheel or a plasma cutter....but those all produce alot of sparks.
Old 09-07-2009, 01:06 PM
elitecustombody's Avatar
agreed with above post ,you can also try the air nibbler
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 09-07-2009, 06:52 PM
You can also use a reciprocating saw - with a steel cutting blade - it's a bit clumsy but you can do it... I like Ned's idea of using a 'body saw' - the small air driven body saws are exceptionally handy! Be prepared to use LOTS of blades... these little buggers can really go through them.
I also use a variable speed jig saw with bi-metal cutting blades in them for some work...
Watch out for those BRACES underneath -- mark them if you're cutting from the top -- you'll want to drill out the spot welds in them and keep 'em in place...
Old 09-07-2009, 06:54 PM
I have the air shears that Ned shows in his post -- mine rarely get used - they're almost useless unless you have a nice flat clean sheet of metal to work with -- they don't like stuff that's contoured or dirty - or too thick... and they get stuck a lot if you're trying to "push" them through a cut. They also use HUGE amounts of air... so you'd need a big azz compressor.
They're handy when you need 'em though!!
Old 09-08-2009, 04:25 AM
brans72 brans72 is offline
I agree with the air saw ( use it alot lately) the shears are ok but like stated use huge amount of air,only good on mostly flat metal, and got keep the oiled to cut worth a darn. I used a set to take part of my 1/4's off but air saw was the saver of the day. just my .02
