Old 09-03-2009, 08:39 PM
James OLC's Avatar
Default Many Thanks
I wanted to take a quick minute to publicly thank David Pozzi for his incredible help and effort over the last couple of weeks (or months).
Sometimes simple projects snowball and what should be easy turns out to be far more complicated and involved. As pretty much everybody knows, David and Mary have been helping me with the ’67 since spring and the last couple of steps we’ve taken haven’t gone exactly as planned. Not to say that they did not go right – far from it, they have turned out better than I think we hoped – but they took the long route. A couple of times, when we thought we were going to make things easier, they wound up being harder… a couple of other times, one thing turned into another, and then another. Ultimately everything came together but nothing seems to have been easy lately. Through it all, David was there – seeing that it was done, done right, and ensuring that it came together.
To give you some idea how much work has gone into the OLC lately, we’ve got a revamped rear sway bar on the car now with a custom bar coming down the pipe, the entire front steering assembly has been modified; from steering arms to center link to tie rods – nothing has gone untouched. The car has been on a chassis dyno three different times. We have a new T-56 Magnum transmission in the car which required a new shifter and driveshaft. The charging system has gone from barely adequate to better than you could hope for. Every step of the way, David was there and made it happen.
I’ve said many times that projects like ours would not be possible with the help of great people and great companies and I have been very fortunate over the last while to have benefitted from both – Steve Rupp, D*ck, Jon, and Chris at Best of Show Coachworks, Kory and Turn Key Engine Supply, Inland Empire Driveshaft, Classic Chevy 5-speed and Tremec, Jay Harris and Mike at ISIS, David at Hellwig – have all played a part in this and I have to thank them as well.
David (and Mary and Ruby) thank you so much. I hope that one day I have the opportunity to pay this forward.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
