Old 08-28-2009, 10:29 PM
g356gear's Avatar
g356gear g356gear is offline
Default Hot engine - no start
On hot days when my bigblock gets up to temp, it does not start. It's not all the time, just occasionally. When it does it, I don't even get a click out of the starter. If I wait 15 minutes, it starts right up. Is this a case of a starter issue or just excessive heat from the headers on the starter that could be answered with an insulator wrap on the starter? Thanks for any feedback.
Old 08-28-2009, 10:39 PM
70rs's Avatar
70rs 70rs is offline
It sounds like heat soak to me. Have you tried wrapping the headers or starter? That may take care of it. Or a starter shield may do the trick.
Old 08-29-2009, 11:53 PM
g356gear's Avatar
I picked up a Thermotec starter wrap today to try. We will see if that does the trick.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 08-30-2009, 02:11 PM
Yeah --- sounds like heat soak to me too...
A mini starter will give you some more clearance - just don't buy the cheap chinese versions... and some of these allow you to index the solenoid (or clock it as some call it) == and I've seen guys clock this down to the bottom away from the heat/headers.
I was having this issue on my lamely built 37 ford with a super mild 350 SBC -- pulled the starter only to find the studs in the back of the starter AND the solenoid were both loose... put them back in properly (I didn't install or build the car) and everything cranks up just the way it should now.
Old 08-31-2009, 03:13 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Had the same problem with my Camaro and Chevelle. The headers heated up the starter. I switched to a mini starter and clocked it away from the headers and the problem was solved. Hope that helped.
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 09-10-2009, 09:18 AM
g356gear's Avatar
I ended up wrapping up the starter with a heat shield and it seems to have worked. Went for a 1hr drive on the weekend and the car started right up after shutting it down for a few minutes.
Old 09-10-2009, 11:27 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Good to hear. Hope that was the problem solver!
Old 09-12-2009, 12:40 PM
70rs's Avatar
Very cool! No pun intended... I'm glad it seems to be resolved.
