Old 03-26-2010, 07:09 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default Preparing for the Midwest Muscle Challenge
Okay - I'm doing some little things to get my 69 Camaro ready for the www.midwestmusclecarchallenge.com
Started out with installing a set of Morris Classic 3 point retractable seat belts up front. It previously had only a lap belt system. I appreciate all the input about four point cage sytems vs. this for what is otherwise a street car that uses the back seat.
I also put a steam T in my upper radiator hose to catch the steam line out of my LS engine. I had previously only capped that and had no issues for 11K miles, but this will really heat things up and I want to make sure the air bubbles get out of the engine. I don't have a port in my radiator, so this was the next best.
I am flushing the system and running Wilwood 570 and bringing and extra bottle to drain it out after the road course to make sure I get any bubbled fluid out. It is due for a flush anyway.
I ordered 10' of Jegs 3" brake duct. I don't know how, but I will be working on porting it from the nose to the hubs to help cool it down - this car is heavy with A/C and all - so these C5 front brakes will be working very hard.
On April 23 I'm taking it to www.speedinc.com to dyno tune the engine. Up until this time it has been running on a mail order tune.
Of courese, we'll wrap it up with a full fluid change, and bolt check.
What am I missing????????
Old 03-26-2010, 07:44 AM
Payton King's Avatar
Default Not sure how hard you are going to run
but i would change brake pads to a more aggressive set or at least bring another set with you.
Good luck, you will have the time of your life running a big track.
Old 03-26-2010, 08:16 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Add 1 extra qt of " good " engine oil
Good power steering fluid. GM fluid is very good.
Brake fluids are not all alike, look for a hight boiling point.
Try and get an instructor to ride with you early on.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 03-26-2010, 09:38 AM
69MyWay's Avatar
The Wilwood is a 570 degree dry boiling point.
Do you run an extra quart of oil in the crankcase - or is that to replinsh after running?
Pads???? I have GM delco Corvette pads in the C5 calipers and it is using slotted/drilled rotors.
On the subject of pads....what type would be better than the stock C5 pads that are good for street and track?????
Power Steering.....yes, I need to drain and fill that. The fluid in there now has been there for 5 years and 11K miles.
Okay...any examples of air ducts on 1st gen Camaros????
Old 03-26-2010, 10:02 AM
Bow Tie 67's Avatar
Run an extra quart in the crankcase, and bring another incase you need to replenish.
Pads should be ok, but stock C5 Z06 pads would be better. I dont think you need ducts.
Matt
Old 03-26-2010, 10:59 AM
69MyWay's Avatar
Very cool info.
Yep... I know I dont' need them, but if I can get them hooked up without turning it into a massive project it would be cool. I have to put a support brace on my spoiler anyway. I don't have the ugly OEM rods on there and I suspect it folds back at high speed. I'd hate to tear it off from plastic fatigue. So, while I'm whiping up some aluminum brackets for that I'll eye ball what it would take to put the hoses under there.
Old 04-05-2010, 07:29 PM
Matt, I'm not sure I agree with you. Of course I'm not an LSX guy. Windage is worse than being a little low on oil. It robs power and aerates the oil making it hard for the pump to do it's job. A thicker oil may be a good decision due to the increase in oil temps. I don't think you need the brake ducts for the length we run the cars. This isn't Lemans 24hrs. haha
Old 04-05-2010, 07:43 PM
Grnova's Avatar
Grnova Grnova is offline
I have been trying to prep for this event also. Just added a new 55 GPM electric water pump.
I have been looking into evanscooling because car is sill running around 200+*
Installed M&R 5 point, cam-lok harness.
And right now trying to get my brakes straightened out.
Is there a place where you can see this track with a virtual tour?
Hey 69myway- What tires are you running? Your car looks great nice Brand of wheels!
Old 04-05-2010, 10:04 PM
GRNova --
Re: Evanscool
Have you just tried adding a couple of bottles of Red Line Water Wetter?
Run - distilled water - no water from a garden hose... and barely any anti freeze -- and at least one bottle of the Water Wetter...
If you're still running hot - I'd have to ask you if you have a fan shroud? Electric or engine driven fan? If electric - are you getting full voltage? If electric are you using relays to the fan(s)... If engine driven - how close is the fan to the radiator? Are you using an anti collapse spring in the suction side hose? You may be collapsing your lower radiator hose...
But in the end - nothing wrong with running 200 degrees --- new Vettes run 220.... it's only really a problem if the temp keeps climbing.
Old 04-06-2010, 03:37 AM
69MyWay's Avatar
They are Nitto Neogen - 18" up front and 19" in the rear.
http://www.nittotire.com/#index%2Etire%2Eneogen
They are not typical "directional" tires - but they are left/right tires. The tread it really cool looking. They came highly recommended by Discount Tire at the time I bought them.
I have no idea how they will perform in this kind of activity. They are now just over a year old but only have about 500 miles on them since.
