Old 12-23-2009, 12:40 PM
67ragtp 67ragtp is offline
Default recaro seat sliders and mounting
Who's slider have you guys been using to mount recaro's in a first gen camaro? Do they make a bolt in bracket? Are the sliders made by recaro. Im concerned about the seat height and curious how you mounted yours with mods or with out. Pretty much going with the speed s.
Thanks Rich
Old 12-24-2009, 06:36 AM
nvr2fst nvr2fst is offline
Rich, Try to locate a damaged Mazda Rx8, the sliders on the 09 models I believe are different than the previous years which should be all the same.
They come with Recaro seats
Old 12-25-2009, 05:00 AM
Thanks Dave- I will look in to it.
Merry Christmas - Rich
Old 12-27-2009, 06:08 AM
Jon69RagTop Jon69RagTop is offline
Default Wedge Engineering
Hey Rich
Try this: http://www.wedgeengineering.net/
They make all sorts of seat brackets.
Jonathan
Old 12-27-2009, 03:04 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Hey Rich,
I've got the Wedge engineering seat brackets, and they work just fine. Only minor complaint might be that some modification may be required if you want to drop the Recaros down all of the way as the seat belt bolts hit the mounting bracket on the seat if you've got it on the lowest setting. Its hard to describe, I can get you pictures this week if you like. Regardless, if you're worried about height, they still sit pretty low on the middle setting.
Matt
Old 12-28-2009, 05:07 AM
Originally Posted by 69MSA View Post
Hey Rich,
Matt
Matt- If you have time pictures would be great- Thanks Rich
Old 12-27-2009, 10:43 PM
T-Type T-Type is offline
the recaros only come in a specific model...it may have been the WS3 package....for some reason that sounds right....however i'm probably off. just an fyi.
edit: i just checked.....it's the R3 package.
