Old 01-21-2010, 12:31 PM
crazyshopmonkey's Avatar
crazyshopmonkey crazyshopmonkey is offline
Default Air Fuel Ratio?
I have the FAST Wide Band Air/Fuel Ratio Analog Gauge in my ride and I just added Aluminum heads and a Compu-tronix distributorless ignition, just curious whats a good Air/Fuel Ratio to run on a 1968 small block camaro or just get some basic starting points on some settings from someone with experience with these
One Less Prius
Old 01-21-2010, 12:43 PM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
I recently purchased the FAST dual A/F metering system for my car and had the exact same question and found the following links very useful:
http://static.summitracing.com/globa...ca170401&2.pdf
http://www.carcraft.com/techarticles...ter/index.html
http://www.innovatemotorsports.com/resources/Stan1.php
Hope that helps!
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 01-21-2010, 12:50 PM
Default air/fuel
AWESOME good info, I will spend the next few hours at work looking at the links
One Less Prius
Old 02-18-2010, 11:28 PM
ken67 ken67 is offline
You can easily run your car at 13.5 everywhere and 12.8 at WOT. This is not "ideal" but it will run well enough tho tune it. You can than try leaner mixtures under light loads and cruze conditions, say 14- 14.5. Dont fall into the 14.7 trap you will pull your hair out . These ratios may be possible and sometimes leaner 15:1 ratios are achievable. Let me know how it goes and good luck
