Old 03-11-2010, 05:25 PM
GeoffP GeoffP is offline
Default Spacer between hub and rotor?
I need to space the rotor on my 87 IROC out by about 1/16" in order to properly center the rotor in the caliper bracket. There is no way to reposition the bracket inboard without re-machining the mounting point on the axle (which isn't something I have the sources to accomplish locally). I have looked at 1/16" wheel spacers. The problem with this is that the spacer HAS to fit up inside the rotor hat. I saw some "stock car" spacers on a site that I thought might work, but they are 5x5 instead of 5x4-3/4. Suggestions???
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
Old 03-11-2010, 08:43 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
I had to do the same thing on the rear of my car. I found a shop with a laser cutter measured the OD, ID, thickness and bolt pattern and had shims laser cut. He cut me about 8 shims so I would have spares for $30. Good Luck.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 03-12-2010, 05:15 AM
Anybody know of a place that'll do this by mail? I really need to get this done soon.
Thanks for the info - wish I had someplace local that did that! Hopefully someone will chime in. Surely one of the shops on here either has a laser cutting machine or knows someplace that does?
GeoffP
Old 03-12-2010, 05:47 AM
GaRys69 GaRys69 is offline
Could you use a 1/16" thk washer on each stud?
Gary Rys
69 Camaro
Old 03-12-2010, 05:51 AM
Patrick's Avatar
Patrick Patrick is offline
Please don't do that.
1968 Camaro--LS1, Kenne Bell Twin Screw
http://www.cardomain.com/ride/2486483
Old 03-12-2010, 07:40 AM
Sti_Guy's Avatar
Sti_Guy Sti_Guy is offline
Couldnt you use a drill press and a circle cutter and make your own 1/16 is pretty thin. Or use some Abs plastic to make a template and send it off to any machine shop.
