Old 02-25-2010, 02:40 PM
tmadden's Avatar
tmadden tmadden is offline
Default Tko 600
For you experts and experienced gearheads.
Why wouldn't I put TKO 600 behind my LS2?
Old 02-25-2010, 03:09 PM
71RS/SS396's Avatar
No reason not to,it is 50 lbs lighter than a t-56 and usually require less modification to the car to install.
Old 02-25-2010, 03:33 PM
monza's Avatar
monza monza is offline
Because you could put a T-56 Magnum...
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 02-25-2010, 06:36 PM
tmadden's Avatar
On a budget. T56 appears out of my range.
Old 04-07-2010, 11:16 AM
Josh69 Josh69 is offline
There is no real good reason NOT to get the TKO unless you have 1400hp. Cheaper, easier, stronger out of the box. If the T56 had more useful gears, it'd be worth it, but 5 and 6 are both overdrives. Choose your rear and your final OD on the TKO based on what you'll be using the car for, and don't look back.
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 04-08-2010, 08:19 PM
tmadden's Avatar
Thanks for the advice and the encouraging word.
Old 04-09-2010, 09:38 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Because you're gonna look back and say, "Dang, I knew I should have put a T56 in it."
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
