Old 03-28-2010, 07:24 PM
66GTFB 66GTFB is offline
Default What cooling systems are you guys running?
Hey fellas,
Just wondering what cooling systems you guys are running? What radiator, water pump (electric or mechanical), and fans (brand, size, cfm #'s), type of coolant, etc and what sort of temps you see?
I'm running a CSR electric water pump and Ron Davis radiator on my mustang and it just won't run as cool as I want it so I'm going to play around with going back to mechanical water pump setup and see what that does.
Any info would be awesome.
Cheers,
Joe.
Old 03-28-2010, 07:52 PM
pokey64's Avatar
pokey64 pokey64 is offline
Good post! I'm researching upgrading our Camaro's cooling system. The ol 454 is running hot...
Interested in seeing what everyone is running.
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 03-28-2010, 09:04 PM
g356gear's Avatar
g356gear g356gear is offline
BBC..stock 4 core rad, with stock fan....185 degrees average, 195 on a hot day. Ceramic coated headers made a huge difference.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 03-29-2010, 04:12 PM
Any other combos guys?
Old 03-29-2010, 04:37 PM
lil427z's Avatar
lil427z lil427z is offline
ron davis
rick k
Old 03-29-2010, 05:35 PM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
69 Camaro with zz454, mechanical water pump, GM BB 7-blade clutch fan, GM BB shroud, 2 core Aluminum BB radiator. Rarely goes over 180 degrees. Has never gone past 195. I agree with the last post, I think the ceramic coated headers significantly reduces the underhood temperatures. My aluminum heads and intake probably help a little too.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 03-29-2010, 07:01 PM
pokey64's Avatar
Here's what came on our car. The radiator says "Northern" on it and looks like a 2 core. The single fan is a pusher and is around a 10" diameter. The fan turns on with the key and stays on. The water pump appears to be stock. The 454 overheats while cruising around town or if I just let it sit and idle.
The old thermostat had some seaweed looking crud in it so I replaced it. Still overheats so I'm going to try some additional air movement with a big fan to see what happens.
Any other suggestions?
//Ed
//1964 Impala SS
