Old 04-26-2010, 08:17 PM
J-440's Avatar
J-440 J-440 is offline
Default Oil cooler question
Was reading another post about oil coolers and a member stated that a MINIMUM oil line diameter should be some -10 lines. Well, if the oil passages in the block are 3/8 I.D. (-6), then what would the purpose of having bigger lines going from the pump, to the cooler, then back to the motor be? I'm looking at adding around 4 feet total of line routing the cooler so what would the bigger lines do for me?
68 Charger, 440SC, EFI, 6-speed
