Closed Thread
Old 09-23-2010, 11:03 AM
fletcherscustoms fletcherscustoms is offline
Default 1970 Camaro "shop beater v.3", 388 blown sbc, BMR suspension, carbon fiber, etc, etc
Well its time build another so my baby must go. This car was just completed a few months ago, and has been driven a few times to work, and done a few autocross weekends with it. This is my personal car, title in hand and ready to move. Car is a 100% ready to go, drive it anywhere you want, great street manners.. Will consider trades towards vettes, bikes, exotics, hell basically anything. Car is currently in my buds stereo shop have a mild stereo installed. Changes can be made.
Heres the details
$45,000 obo
Chad Fletcher
[email protected]
229-two two 1-four six 9 0
1970 Camaro
BODY
-All original GM sheetmetal, no rust anywhere
-Anvil Auto Carbon fiber, hood, decklid, and spoiler (will paint to match for no charge)
-All new glass, and trim
-Custom made front grille that removed stock opening for hood latch, as hood is now secured with pins
interior
-4 Point roll bar. 1.75" .120 wall DOM tubing
-4 point Harness
-Full Bolster seats with harness holes
-New carpet, headliner, door panels, etc
-Autometer Pro Comp gauges in Anvil Carbon fiber bezel
Wheels
-Forgeline 3 piece wheels, black center, chrome lip. 19x10 front with a 285 Invo, and 20x13 rears with 345 INVO
Suspension
-BMR Fabrication Upper and lower control arms
-BMR front Sway bar
-BMR Torque ARM rear suspension
-AFCO remote ressy, mono tube coilovers on all four corners
-Subframe connectors , run from subframe to back bumper 2x4 tubing
-Wilwood 12" 4 piston setup all four corners
-Wilwood MC with custom stainless hard lines
Drivetrain
-TKO 600 5 speed manual, Mcleod bell housing, Centerforce dual friction clutch, and Hayes flywheel
-Aluminum Driveshaft
-Strange 9" housing, back braced, DEtroit true trac, 31 spline axles
Engine:
-388" SBC
-AFR 220 CNC'd heads, Ferrea valves, Jesel rockers
-9.8:1 compression ratio
-Crower forged crank, forged rods
-JE forged pistons, JE blower specific chrome rings
-Manley retainers
-Comp springs
-Comp cam solid roller with comp roller lifters
-Edelbrock Victor JR , fully machined for head intake match
-Comp timing belt
-Stef's Road race oil pan
-MSD 6BTM ignition with MSD distributor, and Moroso crank trigger
-Vortech Centrifugal Supercharger V1-SI trim running 12 psi boost at 8000 rpm
-All accessories, mounts, brackets, etc custom machined and hand made, no off the shelf parts
-Water pump is a custom Evernham Motorsport Nascar unit with high flow impeller
-GM LT1 style power steering pump with remote res
-Nascar TAG mini alternator 130 amp
-BE cool aluminum radiator with dual electric fans
-Fuel System-10AN feed and -8an return Black braided hose with Aeroquip fittings, Aeromotive A1000 pump with billet filter setup
-Ricks Stainless sumped fuel tank in stock location
Chad Fletcher
Fletcher's Customs and Speed
229-221-4690
[email protected]
Old 09-23-2010, 12:57 PM
Wow, sick. Lots of awesome stuff for that price too.
How much power?
Old 09-23-2010, 01:00 PM
Made 645 at 8 psi. Running closer to 12 psi now, so should be a little more
Chad Fletcher
229-221-4690
[email protected]
Old 09-23-2010, 01:40 PM
awr68's Avatar
awr68 awr68 is offline
Do you still have the stock panels and are they included?
Tony
'68 Camaro
Old 09-23-2010, 01:41 PM
I do not have the stock panels. But it can be negotiated for new panels that are finished in color with or without stripes
Chad Fletcher
229-221-4690
[email protected]
Old 09-23-2010, 04:59 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Looks like a nice car and tons of goodies.
Good luck!
Closed Thread
