Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 07-23-2012, 08:00 AM
Tony_SS Tony_SS is offline
Default Lowering an 01-06 Tahoe
Has anyone done this to improve ride quality and handling?
Skull Daddy Graphics
Design / Apparel / Vinyl Graphics
Old 07-24-2012, 07:58 AM
jy211's Avatar
jy211 jy211 is offline
Not on these years, but on other year trucks and suburbans yes. I lifted a 00' tahoe though
Old 09-03-2012, 08:05 PM
elitecustombody's Avatar
Not sure how much different from 02-05 Escalade,which is full time AWD. Adjust front torsion bars and install lowering springs in the rear,also shorten or bend the linkages for air ride sensors.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 09-04-2012, 07:56 AM
tooblue's Avatar
tooblue tooblue is offline
How low are you planning on going? 2wd,Awd,4wd?
Lowering is very easy and depending on how low you want to go would determine the "best" method. Rear is very straight forward = Springs. The front can be turn torsion down (Depending on how low) ,, Replace Torsion keys or replace spindles with a lowered spindle.
When I lowered my 03 I did a 3" front 4 inch rear,, Torsion Keys front , Springs rear shocks all around. The problem with the Keys when going this low is the front end alignment can be a challenge to really get dialed in. The other disadvantage is the ride can be very bumpy even with the bump stops replaced or cut. I have lowered spindles now and will be putting those in so I can get some of the travel back / ride quality back in the front suspension. The only thing with Spindles is you must have a minimum of a 17" wheel. Hope that helps
Roger,,
1995 Caprice,, LQ4 = 6.0 , L92, 4l65e, Phoenix AZ..
http://www.cardomain.com/ride/456803...caprice/page-1
Old 09-04-2012, 11:54 AM
It's a 4WD.
Here's how it sits now
Here's a photoshop of what I'd like
I want a 2/4 drop. Not sure what springs or shocks to use... I plan on decranking the stock keys up front to drop it a couple of inches.. maybe 1.5 at the most.
Old 09-08-2012, 07:35 AM
Tig Tig is offline
I'm pretty sure they sell lowering kits, you can specify what drop and some places will put a package deal together for you. Like said, keys and coils would do the trick.
Thought I'd throw a lowered Hoe in the mix. Spindles coils and flip out back.
