Old 10-18-2010, 09:04 AM
fletcherscustoms fletcherscustoms is offline
Default My 70 Camaro "Shop beater v 3.0" catostrophic engine failure
Well a couple of weeks ago we had a engine failure in my 70 Camaro "shop beater v 3.0". Well this weekend we finally had the chance to get the motor out of the car and do the autopsy. Well upon removing the oil pan drain plug we were greeted with a bout 2 gallons of water before we got any oil. So I knew already we had major issues. The hole in the pan and 7 dents in the pan pointed to big issues any way. But I didn't expect to be as bad as found upon tear down.
After removing the pan, we immediatly notice the lack of the bottom portion of the #4 rod. There is heavy blueing on the crank at the where the #4 rod was, which leads to a bearing or oiling failure of some type. Well it seems it let loose at the cap area and then in turn snapping the rod in half and due significant damage in the mean time. All 8 pistons are damaged, either cracked or broken skirts. #4 cylinder and #3 cylinder walls have holes in them at the bottom. The resulting schrapenal made quick work of breaking the cam shaft in half, which in turn stuck open the valves which then made contact with the top of the pistons, therefor bending every valve. So in turn there is nothing salvagable internally. The heads can be salvaged with a valve job and all new valves.
Everything internally and part of the short block is trashed. Nothing like staring at a $20,000 boat anchor to make your Sunday. Motor assembly was done by Evernham Motorsports Nascar team a couple years back. The detail work inside the motor is insane, every part was laser engraved with location, date of assembly, and sizing info. The valley under intake and all internal area of the motor had been ground down to a mirror like finish. incredible amount of detail and time spent in machining and assembly of the motor. But now all that work, has left me with a new coffee table.
Just thought I would share my grief and heartache with all my buddies. If anyone has a lead on a stroked or cheap LS take out motor please let me know. I'm thinking big cubed LS with a carb. Keep it simple and get it back on the road ASAP. Back to my sulking and depression!!
Chad Fletcher
Fletcher's Customs and Speed
229-221-4690
[email protected]
Old 10-18-2010, 09:44 AM
6D9 6D9 is offline
Thats why I pulled my Procharger off for fear of doing just that!! I agree on the carbed LS!!
PS...sucks to hurt such a nice motor..I would be crying as well.
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 10-18-2010, 10:37 AM
Ron in SoCal's Avatar
So sorry Chad. It just goes to show you, engine failure can happen no matter how detaied the build process.
I may have a line on an LS drop out and will check for you. I also sent your number to a buddy whose daughter has a repair issue in Tn very close to the GA border. Being the only guy I know in those parts I figured you would either help a damsel in distress or know someone who could. I'll be in touch on the motor if it's still available...
Ron
Ron in SoCal
69 Camaro in progress
Old 10-18-2010, 11:16 AM
yeah it happened with a whopping 698 miles on it!!! But oh well, I built the car to drive and enjoy. Just part of paying the price to play with the big boys!!
I'm in the process of listing a "yard sale" for all the good parts off the motor. Lots of good parts, with some killer prices!!
Chad Fletcher
229-221-4690
[email protected]
Old 10-18-2010, 12:40 PM
pavell's Avatar
pavell pavell is offline
wow. how much psi were you running with that motor?
Old 10-18-2010, 12:48 PM
12 psi
Chad Fletcher
229-221-4690
[email protected]
Old 10-18-2010, 12:57 PM
cdushane's Avatar
cdushane cdushane is offline
Dude, that sucks! I know the feeling though, a few years back I blew the motor in my Z06
Chris
Old 10-18-2010, 01:01 PM
It was funny everyone was sticking around the shop "to watch a grown man cry"!!! Very bad day to say the least. But someone is gonna get some killer pricing on the goodies that come off the motor
Chad Fletcher
229-221-4690
[email protected]
Old 10-18-2010, 05:55 PM
out2kayak out2kayak is offline
Wow, Chad! That really stinks.
Hmm.... Time for an upgrade?
You know, to help you recover from the loss of your old engine.
-- Joe
Old 10-18-2010, 06:10 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Been there. Sorry to hear you're having to go through that. However...this is how things end up getting faster. lol
Keep your chin up!
Curtis
