Old 12-08-2005, 05:29 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default LS1 long block and parts f/s
2000 Corvette LS1 with broken #7 rod and cracked block. Car sucked up fresh water and hydrolocked upon start-up.
Crank appears okay (will need to be checked)
Block "may" be fixable but no guarantee. It will at a minimum make a nice donor for fitting/building motor mounts to mate a LS1 to another application.
Intake is a F body style with EGR (plastic is sun faded)
Fuel rails and injectors included.
Valve covers
Front and rear cover
Lifter valley cover
crank balancer
timing chain
oil pump
Corvette oil pan (undamaged)
Block is mostly disassembled.
No coil packs
No wire harness
No accessories
No manifolds
$250 if you pick it up from zip code 33823
Will deliver within reasonable distance for $300 (will take it to Jacksonville, Orlando, Tampa, Ocala, Gainesville...etc).
[email protected]
