Old 02-18-2011, 11:10 AM
6carmello8 6carmello8 is offline
Default How do you measeure side wall height ! ! !
I've searched and I found a converter but the answer contradicts the tire rack guy.
How do you measure side wall height?
Thanks!
Old 02-18-2011, 11:28 AM
ccracin's Avatar
ccracin ccracin is offline
A 295/40 20 means the tire section width is 295mm. The 40 means the aspect ration or (Side Wall) is 40% of 295mm or 118mm divide by 25.4 and you get 4.64". You would then subtract the lip height if you want viewable rubber. Hopefully this will help. Maybe one of our tire and wheel experts will correct me if I blew it. This is my understanding.
Good Luck!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 02-18-2011, 12:07 PM
There it is!
