Old 05-17-2011, 09:44 AM
murvilboy's Avatar
murvilboy murvilboy is offline
Default C5 Z06 Wheels on 72 Camaro
I have a set of Z06 Wheels from a C5 Corvette and i want to throw them on my 72 Camaro. I know I would need spacers but what sizes and what size tires should I run on the wheels? It is stock height but Im looking to lower it if there is any room to do so. Any help regarding this situation will be greatly appreciated.
when life passes you by....downshift!
Old 05-17-2011, 12:27 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Unless someone has done this already, you may have to mock them up & take some measurements. Z06 wheels are 1" wider than stock C5 wheels. Are they stock Z06 sizes ot C5 sizes? Some aftermarket companies make those wheels in C5 sizes. Do you have tires on them already? Is the rear mini tubbed? You doing the power tour by any chance?
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 05-17-2011, 01:03 PM
murvilboy's Avatar
they are stock C5 Z06 wheels and the car is not mini tubbed nor i dont wanna do that bc the car is solid so i dont wanna cut it up. im not doing the power tour wish i could but maybe one day
Old 05-18-2011, 07:39 AM
RENN SCHNELL RENN SCHNELL is offline
Go to www.tirerack.com and look up a C5 Z06 stock replace tires. Probably a 9.5" front to fit a 275 tire and a 10.5 rear for a 295 tire.
Old 05-18-2011, 11:01 AM
murvilboy's Avatar
i know what size the stock tires would be but will they fit under the camaro body? i may have to vary with tire sizes in order for them to fit? idk im just wondering and i dont wanna waste a bunch of money or time trying stuff out that dont work.
spacers possible 2" Front and 2.5" Rear? get the spacers with studs mounted on them. i have this same thread setup on two other camaro specific forums and no one is telling me anything. it looks like its going to have to be trial and error the old school way lol.
Old 05-18-2011, 12:15 PM
nicks67ca nicks67ca is offline
If you know your oem sizes you can plug them into this calculator then take the Z06 wheels and plug them in as well. you can then figure out what you need for spacers. you just need to watch the track width so you don't chew up the outside of your tire on the wheel wheel. i did this for my 67 with c6 z06 rims.
http://www.rimsntires.com/specs.jsp
Old 05-18-2011, 12:38 PM
skatinjay27's Avatar
the fronts are 9.5s and thats really wide for a front wheel on a stock frame... it can be done but you cant be too low and youll need to add a bolt to your steering stops to keep them from rubbing a full turn. for the front youll need like 5" of back spacing so measure the true backspacing of the wheels then do the math to find the right size spacer you need. the rears will fit but it will be tight also and youll want 5.75" backspacing so do the same with the rears for finding what size spacer you need. also depending on the ride height youll need to roll your fender lips and and (if you got them) youll need to b.f.h the seat belt humps. also keep in mind factory 2nd gen rears are are offset to the side about .25-.5 inch so one side might need a .25 spacer (i think its the passenger side)
AJ
Old 05-18-2011, 03:56 PM
WILWAXU WILWAXU is offline
I've put 17x9 ZR1 wheels on my '71 Nova. I used 2" spacers on the front (245/45) and a combo of 1.5" and 1" for the back to get the 275/40's under the back.
Because these cars are all a little different you'll have to measure to get the right fit, in my case, even side-to-side in the rear.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 05-18-2011, 05:43 PM
murvilboy's Avatar
first off thanks for help everyone.
nicks67ca you got pics of ur setup?
Old 05-19-2011, 06:19 AM
I can but its for a 1st gen. Let me take some pics tonight.
