Old 05-08-2011, 07:25 AM
NAPA 68 NAPA 68 is offline
Default Aeroquip Teflon Hose Troubleshooting
I am hoping someone here has some experience with Aeroquip Teflon Hose. I have a fitting (fuel) that I cannot get to seal. I have the brass sleeve positioned properly, but still continue to leak from the backside of the fitting(not the flare).
Any thoughts?
Thanks,
Tim
Old 05-08-2011, 07:56 AM
camcojb camcojb is online now
Any thoughts?
Thanks,
Tim
The teflon liner has to be cut very straight and clean. After cutting the hose I usually trim the very end of the liner with a razor blade to get it completely straight and remove any burrs or rough edges on the inside of the teflon liner. It sounds like this may be your issue; if the teflon isn't completely straight and burr-free it will leak.
Old 05-08-2011, 10:56 AM
CarlC CarlC is offline
I agree with Jody. I've had no problems when using this method.
If you have used the compression ferrule once, replace it. Aeroquip offers replacement ferrules.
http:www.vaporworx.com
Old 05-14-2011, 05:08 AM
Great advice guys! You were right on. Dry and tight now.
Thanks for the help!
Tim
Old 05-14-2011, 07:59 AM
Tim
perfect Tim, glad you got it fixed. A lot of people don't realize it seals on the end of the teflon liner, which is why you need to spend a little time to make sure it's clean and straight.
