Old 11-21-2005, 06:29 PM
Travis Rankin Travis Rankin is offline
Default Windshield tech??
Right now the car' windshield is held in by a seal, and then the chrome stripping finishes it off..
I want to build up the pocket and have the glass, front and rear, to be almost flush with the body, and then just glue in the glass, like in a newer car. and eliminate the chrome
So is it a good way to do it? any special techniques I should employ in installing the glass? Is there a rubber spacer in there, or is it just glued to the steel? what would you do to fill the small gap and the edge of the glass to match it up to the body?
This site rocks
Thanks for any light you can shed
Old 11-21-2005, 07:47 PM
orange88 orange88 is offline
just use a really large bead of adhesive the one problem is yourgoing to have a huge gasket to cover up thegap andlook right
Old 11-21-2005, 08:06 PM
907rs's Avatar
907rs 907rs is offline
You'll have to add metal to the seating surface as well as close up the opening dimensions. (Height and width) Most guys use the rubber seal from an S-10 truck to hide the gap; it's got a small profile and looks clean IMO.
Bill
Old 11-22-2005, 07:18 PM
67Sally's Avatar
67Sally 67Sally is offline
There is some good information about flush mounting the windows at Dennis Linson's website
W.
William Rouleau
Project PonySnake
Old 11-23-2005, 10:58 AM
rwhite692's Avatar
There was a car at SEMA, a 69 Camaro, in which vendor's booth I can't recall, which had the windshield and the rear glass done this way,...I can't say that it looked very good or would be worth the work (Just my opinion) but perhaps on an all black car, it would help to pull off a certain "trimless" look...on the car I saw at SEMA, it seemed to just make the glass seal more obvious and ugly than it ever was to begin with...again just my $.02. -Rob
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 11-24-2005, 02:25 PM
Im pretty sure I am going to do it, i like doing all the neat little stuff.
I have a glass shop next door and he has some great little bulk windshield weatherstrip, I think i might just be able to pull it off
