Originally Posted by 454SSguy
Wait, what? Is there a stand alone controller to use this tranny with. Last I heard there was not and it could only be used with an 08+ ECU. Is that still the case?
Sorry 454ssguy , i should clarify. Mastmotor sports told me i would need to use there ecm and hareness , there ecm tells the trans controller what to do and the trans controller is inside the trans, i was told.Speartech is also working on this set up , i believe they are using a gm ecm to control the trans.Speartech has been doing this set up for awhlie now.
