Old 07-04-2011, 10:49 AM
g356gear's Avatar
g356gear g356gear is offline
Default Tach quits at 1500 rpm's
My repro tach has decided to work normally below and up to approx 1500 rpm's and then quits past that rpm level. Once the engine revs drop back down, it picks back up again and operates normally. Ideas?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
