Old 06-26-2011, 04:32 PM
chevmech1969's Avatar
chevmech1969 chevmech1969 is offline
Default 5.3l 4l60e swap ready. nebraska $1500
In North platte nebraska, Asking $1500
Ive got a 00 5.3l engine and 4l60e trans that is ready to install into your hotrod, truck, car. the wiring harness is modified for no rear o2 sensors, evap, egr, security, or ac controls. the computer is tuned, its got everything from the oil filter to air filter. the engine has the famous gm piston slap when it is cold outside. i swapped this into my 84 chevy truck, it worked flawlessly, got 16mpg intown and 18 on the highway. it took several trips to denver and omaha. it probubly has around 130,000 on it. it is a 4x4 trans, that has been rebuild professionaly. i can have them install a 2wd outputshaft and tailhousing if you would want that. $100 exta the only reason i pulled it out is i bought a 01 gmc sierra extended cab it fits the kids and wife alot better. you can call or text or pm anytime i will get back if i dont awnser. 308-660-oner sixer four niner.
give me your zip and i can get you a shipping quote so far to the western part of colorado and utah is around $300-$350ish
ill throw in the tcase if anyone is putting it into a 4wd.
Yes it still has the truck oilpan and intake on it.
No, it doesnt have the air conditioning compressor or bracket.
here is a link of the truck startup and engine walk around.
Johnson's Rod'Z
A man with few vices, has damn few virtues.-Benjamin Franklin
