Old 07-30-2011, 08:22 AM
JustinB's Avatar
JustinB JustinB is offline
Default New Centerforce DYAD Clutch Pics, rated at 1200 ft/lb!
I received my new Centerforce DYAD clutch setup and thought I post some pics for guys who might not be familiar with it. This is going on my 540 BBC with a Tremec TKO-600. Clutch comes complete with flywheel, drive disc, floater plate, floater disc, pressure plate, and all the necessary hardware for install. The clutch comes completely balanced and was rated with a holding capacity over 1200 ft/lbs. I am very impressed with the quality out of the box and install was a piece of cake. As soon as I get it on the road I will update this post with overall driving impressions
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 07-30-2011, 11:42 AM
orangevert's Avatar
orangevert orangevert is offline
That looks serious, I say your better off building stuff for more hp then you'll ever use then replacing it all the time..
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 07-30-2011, 02:04 PM
67ragtp 67ragtp is offline
Hey Justin
Funny, I was looking at that thing this morning on centerforces website, looks great. Im curious, are you setting it up with a hyd throw out bearing or going mechanical? Do they specify a special bearing for it? any chance you could give us a price range on it?
Very nice looking piece, Im very interested in your review of it, pedal feel, noise from floater disk etc.
Thanks for posting it - Rich
Old 07-30-2011, 03:33 PM
That does look like a sweet set up. The only negative I see is the proprietary flywheel. How heavy is it?
