Old 09-14-2011, 05:21 PM
knucklebusted knucklebusted is offline
Default Play in Front End AFTER New Parts
So, anyone with power steering knows how much play is in the wheel when the car is off and the steering isn't locked, about 2-3 inches before it gets real hard to move, right?
Well, my '70 Buick Stage 1 GS, after putting all new tubular control arms, all new ball joints, tall upper ball joints, all new springs and shocks, new idler, drag link and sway bar bushings and a new/reman close ratio steering gear box last year with a performance alignment 2 months ago, it doesn't feel as tight as it should be.
The car has stock disc spindles, stock ride height with stock springs and stock 15" chrome wheels. I like the stock look but want it to corner on rails, which it does much better than stock.
Going down the road at slower speeds it feels like it is wandering, like the gear box is worn out or the idler is shot. They feel good as individual parts but it still seems to have play at center around 25-45.
The alignment was +4 caster, -1 camber and 1/16" toe in total. I realize the added caster can make it harder to steer and may be magnifying the effort to move the wheel.
Could my toe need adjustment? Would I need to go closer to 0 or closer to 1/8" to make it more stable?
Old 09-14-2011, 06:24 PM
What about the rag joint? Tie rod ends, and wheel bearings?
Old 09-14-2011, 06:49 PM
Checked the wheel bearings, they were good. Rag joint was new with the steering box swap. Tie rods aren't new but had no play when I replaced the drag link along with the idler. Alignment shop didn't note anything either
Bearings in the steering shaft don't have any play either. I will double check all that this weekend just for good measure because I did have the column apart and the bolt at the outside firewall was a little loose when I disassembled it.
It feels like I can move it 2-3 fingers worth at 30 MPH without it affecting the direction. Sort of like the old farm truck my grandpa had when I learned to drive a stick. I know it will never be as tight as a rack but it should still be at least as good as say a Grand National.
Old 09-14-2011, 07:52 PM
You have to be missing something. How about the pitman arm?
Old 09-14-2011, 07:55 PM
Pitman arm is non-wear item on an A-body. I'll go over it again this weekend. I'll have the wife wiggle the wheel while I work my way down the steering shaft, trying to find some play.
Get your mind out of the gutter!
Old 09-14-2011, 08:14 PM
The proper way to find play in a front suspension is with it loaded. Jack it up by the lower control arm and grab the wheel at 3 and 9 and then 12 and 6. With the suspension at droop, the parts are out of their normal range and won't show slop.
