Old 08-23-2012, 05:18 PM
Default LS1 fuel starvation problem??
I have a 2nd gen Camaro with a 2002 LS1 and spectra fuel tank with a Walboro fuel pump. The problem is when I go around a sharp turn accelerating through the turn it acts as though it is not getting any fuel even with the tank almost full. I have to take my foot off of the gas pedal to get it going again.Could this be anything other than the fuel tank or pump? I know this probably isn't the best tank available but it was in the car when I bought it.
Thanks, Kevin
Old 08-23-2012, 09:44 PM
spectra pickup?
Old 08-25-2012, 04:23 PM
I am not sure, what pickup is in there, I assume your saying that the Spectra pickup is a POS?
Kevin
Old 08-25-2012, 05:31 PM
dhutton dhutton is offline
Kevin
Yep, pretty much. Although this is the first I have heard of one that doesn't work well when almost full.
Old 08-25-2012, 06:01 PM
CarlC CarlC is offline
Almost full? How many gallons are in the tank when it happens?
http:www.vaporworx.com
Old 08-25-2012, 07:14 PM
ccracin's Avatar
ccracin ccracin is offline
OP, you just happen to have the resident expert on fuel systems jumping in here. Carl will help you out for sure!
Chad
Instagram - @cctek
68 Chevy Pickup Project
