Old 04-08-2012, 03:23 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default Valve Stems?
I need help finding a valve stems for my 18x12 rims with a flat lip. Running 6p baer brakes and the stems im using hit the caliper. Is there a smaller one im needing to use with this set up?
Thanks for your Help!
WicKeD
Old 04-08-2012, 03:42 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Whick one do you have know? Do you have 3 piece wheels where the valve stems comes thru one of the bolt holes? They make a vlave stems that's flat that sits behind the center of the wheel and sits nearly flush with the inside lip.
Scroll half down the page and see what I'm talking about.
http://rockcrawler-mrt.com/BEAD%20BR...0by%20MRW.html
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 04-08-2012, 04:00 PM
WicKeD_SS's Avatar
I have Intro two piece wheels where its half way back inside the rim. Looks like a step lip behind the face of the rim. Dose that help?
WicKeD
Old 04-08-2012, 05:02 PM
Musclerodz's Avatar
There is a flush mount stem I have seen. google it, several choices will come up
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-08-2012, 06:20 PM
WicKeD_SS's Avatar
Great ty for the help!
WicKeD
Old 04-12-2012, 10:19 AM
69znc's Avatar
69znc 69znc is offline
Default flush mount
i got my flush mount values from DSE. Do not forget to get the stem that mounts in the valve to put air in! Not that I did that when I first picked them up!
Old 04-12-2012, 04:05 PM
DRJDVM's '69's Avatar
Summit has alot of choices..... I had the same issue so I ordered a couple of different ones from different companies and picked the ones that looked the best and would work.... Then returned the rest
