Old 01-27-2012, 09:29 AM
turboapex turboapex is offline
Default LS-9 transmission ?
Which one can you use?
Old 01-27-2012, 10:58 AM
hifi875's Avatar
hifi875 hifi875 is offline
a 6l90e will work. my father in law ran one for a while in his chevy II, but it was huge and you have to run low numeric gear ratio because of the gearing in the tranny. a 3.89 was too much imo. ended up taking it out and going t56 magnum. so much more enjoyable!!
Old 01-27-2012, 12:09 PM
Thanks for the info.
Old 04-08-2012, 03:45 PM
morris69 morris69 is offline
What did u end up going with. I have a ls9 and want to run an automatic
Old 04-13-2012, 12:11 PM
So ur ls3 with the charger. Has more power than a ls9. I have a 1969 camaro
Old 04-13-2012, 01:33 PM
Stielow's Avatar
Stielow Stielow is offline
I'm running a T-56 modified by D&D Performance and it has work great.
My LS9 in now 427 CID and makes 830 ft*lbs.
Stielow
