Brake line Diameter for 68 camaro
11-26-2012, 08:28 AM
TheChief
Guys,
I am thinking of pulling out all my old brake lines and replacing with stainless when I do my brakes this winter.
The setup will be as follows:
Detroit Speed Brake master cylinder and booster
Front:
Dynapro 6 Piston 12.19" Disc
Rear
Dynalite 4 Piston 12.19" Disc
Braided hoses all round.
I have been told that the DSE master cylinder requires new lines as the holes are in a different position.
my question is, what diameter line should I go for?
Cheers
Jonny
TheChief
Find all posts by TheChief
2
11-26-2012, 08:33 AM
youthpastor
the factory disc drum combo was 3/16 front 1/4 rear.
I would replace it all with 3/16 because of the 4 wheel disc and put an adjustable proportioning valve on the rear system somewhere
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
youthpastor
Find all posts by youthpastor
3
11-26-2012, 09:18 AM
TheChief
Thanks for the reply Youthpastor, would a distribution block mounted proportioning valve be suitable?
Edit: something along the lines of the below (and therefore do away with my existing distribution block):
http://www.jegs.com/i/Stainless+Stee...0730P/10002/-1
09:53 AM
TheChief
4
11-26-2012, 12:04 PM
youthpastor
yep- that should work great
[SIGPIC][/SIGPIC]
youthpastor
5
11-28-2012, 02:13 PM
Apogee
Originally Posted by
TheChief
Nothing against SSBC, but you can get something very similar from Wilwood with their
260-11179
, but for about $50 less.
Tobin
KORE3
www.kore3.com
Apogee
Visit Apogee's homepage!
Find all posts by Apogee
Linear Mode
Switch to Threaded Mode
01:00 PM
