Old 01-06-2013, 04:24 PM
windycitychev windycitychev is offline
Default Forgeline ZX3R for 68 Chevelle fitmen
Hey guys I have a 68 Chevelle and was looking into getting these set of forgeline wheels would they fit my 68 Chevelle SS, I have tubular control arms all around with coilovers, with strange axles and wilwood kit numbers
140-7675-D R
140-7149-D R
I need help before I buy
FRONT
18x9, offset 36, B.C 5/4.5, Hub 70.6,
REAR
18x10, offset 44, B.C 5/4.5, Hub 70.6,
Old 01-06-2013, 07:42 PM
FETorino's Avatar
FETorino FETorino is offline
140-7675-D R
140-7149-D R
FRONT
REAR
If I am reading your stats correctly and those are 5 on 4.5 in bolt circle they are Ford pattern and will not fit your Chevelle.
Rob in SoCal
Old 01-06-2013, 08:53 PM
Is there any possible way they could fit??
Old 01-06-2013, 09:36 PM
Apogee Apogee is offline
You could redrill or replace your rear axles for a 5x4.50 wheel pattern, but for what purpose? The brakes you specified are forged Dynalite kits, where the front hubs have both the 5x4.50 and 5x4.75 wheel patterns and the rear rotors are drilled for 5x4.50/4.75/5, so anything is possible...but the 5x4.50 pattern is weaker and therefore less ideal IMO.
I'm guessing the wheels are used and therefore as-is? Are your Strange axles drilled for multiple patterns already?
Tobin
KORE3
www.kore3.com
Old 01-06-2013, 09:44 PM
Tobin
KORE3
Wheels are spanking brand new never even been mounted to tires or mocked up super sweet deal. The stranded exiles are drilled multiple patterns already. So is there any hope they would work
Old 01-06-2013, 10:16 PM
Ron in SoCal's Avatar
Could be worng, but I think the BS math kills the deal. You need wheels originally spec'd for your car.
Ron in SoCal
69 Camaro in progress
