Old 06-02-2013, 09:29 PM
1Bad68Cat 1Bad68Cat is offline
Question Shockwave Length?
Hello All,
Here is the current setup in my brother's 66 Mustang.
Heidt's Mustang II cross member - PN PX-320-E
Wilwood Pro Spindles 2" drop - PN 830-9807
Ridetech StrongArm Lower Control Arms - PN 19012899
Shockwaves, HQ Series - PN 21120305
Tire Size - 255/40-r17
Background:
I mocked up the Shockwaves to verify I had all the clearance I needed around it. I then proceeded and made pseudo shocks to hold the car up at ride height using the dimensions in the ride tech catalog. Herein lies the problem. At the 11" shock length, the car sits too low and the fender sits on top of the tire. I needed to install a 1" spacer on top of the pseudo shock stud to get to the ride height I was looking for. At the 11" shock length, the lower control is pointing ever so slightly up and with the 1" spacer, slightly pointing down, all when viewed from the front.
Questions:
  1. How is the Shockwave ride length measured for stud types? My assumption is from the center of the lower bearing to the top of the lower delrin bushing on the shock stud. Is my assumption correct?
  2. Since I cannot deviate much in shock length, is there a longer shock stud mount available that can be swapped out to get the extra 1"? Putting a spacer underneath the mount is not really an option because there would not be enough thread engagement at the top.
  3. Is there an issue with my conglomeration of parts above other than it being Mustang II based? I'd rather not get into how we got to this point as it is a long story.
  4. Swapping parts (more money, at least expensive ones anyway) isn't really an option right now as my brother has a newborn on the way and we're trying to finish the car before then (~2 months). Are there any suggestions getting the extra 1" in shock length I need that I may have missed?
Thanks in advance.
Robert
