Old 08-06-2013, 11:13 AM
cjsgarage cjsgarage is offline
Default Glassman's car
Hey y'all. Maybe some of you have some more support for this issue. Finally got the car running sweet-exhaust solved many issues. I was up late last night repinning the harness and flashing an F-Body computer to run the Camaro. Runs great. Lack of traction in forward gears. Just great. Except it won't do a donut. Mike's a pretty tolerany guy (not sure who's garage it spends more time in..) but for the money I'd think it should show off from time to time. But it won't. Deleted all the torque management and running nearly the same tune I'm running in another car that does donuts perfectly. I can't think of what I'm missing. Last I checked, lateral g's don't turn coils off and don't affect compression numbers. Must be fuel. I called Spectra on the tank (GM42AFI) and they say there's no roll-over valve or anything else that shuts off. They suggested starvation, but this is a on/off feel. Not a stutter. Ideas?
maybe PTaddict will pick this up: Do you think the 85mm MAF tuning could be the issue? I'm not losing stoich, and it'll rip tires loose in straight lines or in sweeping corners. Just not tight circles. It's the only major difference between this tune and another car I did not too long ago. I haven't tried reinstalling the 78mm as it would require cutting the immaculate harness I slaved over. (running HPTuners with a 2001 FBody ECU now)
Old 08-06-2013, 12:14 PM
Cj,
What does it do when you try to whip it? Stall out, sputter, back fire or just goes straight?
Old 08-06-2013, 01:21 PM
stalls out. If you push the clutch soon enough you can save it from full stall. But it's like someone flips the off switch when it sees the car swing. I thought it was the "undeletable" traction control on the GTO computer, but that doesn't seem to be the case
Old 08-06-2013, 01:32 PM
Cj,
I guess a more thorough answer would help.
It does not go straight. Suspension is killer and alignment is right on. It's trying, just won't keep em spinning. Gets halfway through the arc and shuts down.
It does not sputter to a stop. It goes from 4500RPM to dead. No back fires. I tried posting a thread in HP Tuners, too, just in case. I just don't think it's the tune. Truthfully, I'm ready to take this tank out and fabricate one. Or drop a pump I can vouch for in. But I was hoping someone else running the Spectra stuff could chime in with a similar experience or the fact that they've had no problems doing smoky circles with their Spectra EFI tank.
Old 08-06-2013, 08:26 PM
Z06vette's Avatar
Z06vette Z06vette is offline
How much fuel is in the tank? If its half tank or less it could be starving. Especially if its an older version. Just my experience with some of the ones I ran in the past.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 08-06-2013, 09:56 PM
glassman's Avatar
glassman glassman is offline
Scott, its a brand new tank, we're thinking the fuel pump may not be enough?
to be continued.....
Old 08-07-2013, 11:34 AM
yep. Definitely got fuel in the tank. Furthermore, the Spectra set up is baffled. Mike and I have been thinking to pull it down and put a pump not made by Spectra in there. I'm thinking Spectra cheaped out on the pump. Maybe after I replace the pump, I'll fill it up. Better than to fill it up before I drop the tank
