Old 09-15-2013, 01:18 PM
Default Foot pedal e-brake and C5 rears
Has anyone retained their factory foot brake while hooking up to C5 rear parking brakes? I'd like to retain my pedal instead of switching to a hand pull but I'm not sure I'll be able to. My thoughts where to get 4th gen LS1 cables since they are longer than C5 cables and have the proper brake connections at the ends. I was wanting to run straight down the side of the car and then route the passenger cable up and over the exhaust and drive shaft after it gets into the rear area where there's room. I'm not sure this would work since the driver's cable will be short and running almost straight back to the caliper while the passenger would be much longer and make all sorts of bends to get over to the passenger side. Granted the cable is inside a sheath that will be restrained along the way so it might work but I'm just concerned about the length differences. I believe I can mount the C5 parking brakes with the pull going towards the front. Any suggestions or experience is appreciated.
Thanks!
Old 09-16-2013, 06:03 AM
nicks67ca nicks67ca is offline
Kore 3 has the drum in hat C5 /6 set up to adapt to GM 10/12 bolt. I purchased that with a Wilwood universal cable set up and drilled out the block and threaded the original adjuster in. Its super clean and works very well. It pulls towards the front I routed my ebrake lines around the 4 link cradle. Also my cables are 2 different lengths and have now holding issues at all.
Old 09-16-2013, 10:49 AM
Thanks for the reply. I didn't think to check with Wilwood for the cables. I tried Lokar but didn't find anything. Taping the block that attaches to the front cable it a good idea. Did you route your cables similar to what I've described or did you go kind of diagonal towards the center of the car like they came from the factory?
Thanks Nick
Old 09-16-2013, 12:15 PM
Hmmm now that i think about it it may have been a lokar kit but either way Kore3 has a universal set up for sale with their c5/6 ebrake system. The routing was down the drivers side frame rail then followed my 4 link cradle across to the passenger side.
Here is the lokar kit I used. The threaded adjuster is smaller than the OE one (at least for a 1st gen camaro)
http://streetperformanceusa.com/i-95...FcqZ4AodxlYAjA
Old 09-16-2013, 12:50 PM
Thanks Nick. I'll look into it some more as well.
Old 09-16-2013, 03:30 PM
73camarols1 73camarols1 is offline
Default Lokar cables
Google ''ec-8001u installed in a camaro''. Sorry I don't know how to post links. Theres a post on Camaro.net with pictures and part #. I think it was a 67 or 68 Camaro.
http://www.camaros.net/forums/showthread.php?t=155939
