Originally Posted by Matt.A
Tim, I have a question, and you seem like the kind of guy who might know the answer. Do you think the smaller throttle body would provide better throttle response between idle and say, 3000 rpm?
Matt
Response / Control / Power / Reliability - all must be considered
There is a few reasons we still build Stielow's supercharged engines with a stock 90mm TB:
1- Driveability - So much so that Mark is able to run autocross courses in 1st gear (with 815 Lb/ft TQ). Seemless control.
2- Power - Have yet to find a larger TB that increases power (with this combination). Total intake restriction is critical on supercharged applications, but we have found reworking the SC inlet (speaking about LS9 style Eaton 2300 TVS blowers), makes considerable diffference at these power levels (880HP in Mayhem). TB still seems to be smaller player in the power gain department. Induction tube is also critical - and we've been working on improving this area as well.
3- Reliability - Have had issues with all larger TB's tried with ETC faults and other issues. Maybe just down to bad luck with parts used, but can't win a race you can't finish.
Should also point out that have not seen appreciable (hardly even measureable) increase in power on stock LS9 with reworked inlet. Or TB change (stock LS9 is 89mm).
Always looking for power, but not willing to sacrifice driveability to get it.
Engineering the details - with data - is best way to make componant selection.
Bottom line - if 90mm is good for 880 SC HP (which is nearly 1000HP worth of fuel and airflow once adding in SC drive losses) - how much differnce can in make at lower power levels?
