Old 11-18-2013, 10:28 PM
Streetrod77 Streetrod77 is offline
Default custom coilover mount
Can someone suggest what I can use to make upper and lower coilover trunnion bar mounts? The lower mount will have to be 4 1/2 inches long. Thanks, Terrence
Old 11-18-2013, 11:35 PM
Also called a T bar mount.
What size are the pivot holes in the shocks 1/2" or 5/8"?
AFCO lists a few but @ 4.00" hole to hole maybe a stretch.
What arms are you running. Room for plates?
Old 11-19-2013, 03:58 AM
I'm not sure about the size but I have found one the is 5" long at Jeg's once I searched under T Bar. This is made by QA1. So I will check with them alone with AFCO. I'm using stock arms. Yes, I thinks its room for plates.
Old 11-19-2013, 07:48 AM
BMR Sales's Avatar
We make a Coilover Conversion Top Kit for A-Bodies & 1st Gen F-Bodies
T.C.
Old 11-19-2013, 11:03 AM
Rod P's Avatar
Rod P Rod P is offline
T.C.
Attachment 43215
DAMN! that's some kinda sexy right there!!!! I will call you guys after this Goodguys road trip, I think I need this for Jane and my other project.....sorry
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 11-26-2013, 08:29 AM
Bryce Bryce is offline
Ride tech and Varishock are another resource for T-bar mounts. call them up and see what they have. FWIW, take a look at my mustang build thread to see how I put coilovers into a stock suspension 65 mustang.
http://www.pro-touring.com/threads/6...el)?highlight=
Old 12-04-2013, 09:28 AM
Chassisworks Chassisworks is offline
Supporting Vendor
Thanks for the reference, Bryce!
We actually have a new program where we will build you pretty much any shock you want. It's simply referred to as the 'Builder Shock Program.'
There is a PDF guide HERE.
