Old 05-10-2006, 02:52 PM
tracy's Avatar
tracy tracy is offline
Default Decision: EFI + Better heads or EFI + Pro Charger on BBC
I currently have a 402 (bored 396) BBC that is practically new. It is well put together with forged crank, H beam rods, 9.5:1 JE pistons. It also has a a Comp roller cam (just under 600 lift). It is balanced, etc..
It has stock oval port heads with roller rockers with Edelbrock Performaer intake and a 780 holley.
I want to up the horsepower, reliability, etc.. My plan was to upgrade to a set of CNC ported AFR oval port heads and go with a Accel DFI setup.
Now I am wondering if I should just bite the bullet and go with a Pro Charger + EFI. If I do this, do I need to upgrade the heads. If I do this plus upgrade the heads will there be a big additional advantage. Is my compression reasonable to use the Pro-Charger in the first place? What kind of horsepower and tork could I reasonably expect to get out of this motor with these options. Would I be better off selling the 402 and going with a much larger BBC?
I would welcome any and all opinions on this loaded topic
Thanks,
-Tracy
Old 05-10-2006, 05:59 PM
Speedster's Avatar
Speedster Speedster is offline
Just my .02 cents -
I would start by going with the ProCharger unit for your present motor. The oval port BBC heads outflow most other GM division hp heads. You are also running a fairly large cam, so the blower will overcome any shortcomings you may think you have unless you plan on running the motor at high rpm. You could get a D1-SC or even an F-1 (same external dimensions) and get quite the bang for your buck. Also, you could get a blow-thru carb for now and switch to EFI later to save some up front cost. There are quite a few people on this board that have used similar combinations and been very successful.
There is a combination similar to yours on the ProCharger website that is listed at 648hp.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 05-10-2006, 06:58 PM
Bruce, you can field my tech calls on Procharging. That was the perfect answer.
Old 05-11-2006, 12:31 AM
tracy's Avatar
Bruce,
Thanks for the excellent advice. I think I will start with the simple route you suggest.
I could not find the listing you spoke of on ProCharger. Can you give me a pointer?
Thanks,
-Tracy
Old 05-11-2006, 05:46 AM
Payton King's Avatar
Default Call Frank at Prodigy
I believe he is a dealer for them
Old 05-11-2006, 12:14 PM
Speedster's Avatar
Thanks Frank.
Tracy, Frank is a dealer for ProCharger so give him a call.
Here is the link to a similar setup:
http://procharger.com/gallery/showte...ket=3&idx=1107
-Bruce
Project "Freebird"
Dyno Video
Project Rides:
2007 Magnum
