Old 05-30-2006, 08:01 AM
KillaCamaro67 KillaCamaro67 is offline
Default How could i make my engine better?
well ive been concidering doing some tidying up of my engine and its problems here and there... but i was wondering.. how could i bring my engine up to its best?
heres my lump so far..
a 406 cubic inch SB chevrolet. This engine is 6.6
The engine block was fully reconditioned (bored .030" over in
the process),
increasing displacement to 406 cubic inches.
Edelbrock Performer RPM aluminum heads (64cc straight plug
chambers)
Edelbrock Performer RPM aluminum intake manifold
Lunati cast crank and pistons assembled for 10:00-1 compression
Lunati "number 10" 292/
292, Lift
.480/ .480
Holley 750 vacuum advance carburetor
GM HEI distributor
The transmission is a TH350 3 speed automatic.
i know a couple of parts on here are older production like the cam, but what could i do to improve what i already have?
or atleast dress it up while i got it out? ...and i know it need a good cleaning too
thanks yall!!
Old 05-30-2006, 10:08 AM
CAMAROBOY69 CAMAROBOY69 is offline
Do you mean the engine itself or your engine compartment? Performance or looks?
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels,Hydratech Hydraboost
ILLUSION Website
--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
Old 05-30-2006, 10:13 AM
Steve68 Steve68 is offline
How does the car run with the cam, I have a bunch of extra parts to make a 383 with close to the same cam, how the power, torque, sound, thanks
Old 05-30-2006, 10:34 AM
id like to make it something very street reliable..
im having alot of vibration with the whole thing, and im not sure if its the cams fault.. my bodyguy said that they might have not balanced the internals properly.. but i asked the guys at protouring and they said it probably isnt that bad..
but i want to make it optimal..
more performance than looks, but if there is a suggestion please let me know!!
But it sounds like a beast and pulls like a bat outta hell!!.. compared to my R32 which is 240hp AWD.. it destroys it in a strait!
Old 06-08-2006, 08:05 AM
markss28 markss28 is offline
Best thing that I have seen in cleaning up an engine bay is with the wiring. Take some of the stuff you dont need out and plug it or rap it with some braided lines. Take a scuff pad and polish everything that can be. Take some degreaser and start spraying. Maybe even buy some billet pulleys. I just bought some from Billet specialties and they were alot cheaper then March's.
Never Stay Stock
Old 06-08-2006, 08:52 AM
Speedster's Avatar
Speedster Speedster is offline
If you are taking it out anyway, I would update the cam. Talk with a Comp Cams, Crane, Lunati cam tech. A 406 can tame a hefty cam and that will bring out the power. If not that, consider changing your rocker arms to a 1.6 ratio for the extra lift and a few more degrees of duration. (Assuming your springs can handle it) But before that, make sure that the engine is balanced properly or there is not damage to the harmonic balancer. What flywheel/flexplate do you have. Internally or externally balanced ?
What coil are you running ? Plenty of spark energy ?
Rearend ratio ? Transmission/gear ratios ?
Any excess weight in the car you can get rid of ?
Just a few things to think about.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
