Old 12-04-2013, 01:16 PM
ADiCarlo ADiCarlo is offline
Default Backspacing Actual Width vs Stated Width
Hi Guys,
When backspacing is measured it's take from the actual width of the wheel not the stated correct?
So a 10 inch wheels center line would be 5.5 instead of 5 to account for the added 1 inch difference between stated and actual.
I'm trying to work with some European wheels that use offset so to calculate the backspacing i'm taking the stated size + 1 inch (for actual) /2 + the mm offset converted into inches.
Also whats the maximum recommended spacer to run on the front wheels?
