Old 12-15-2013, 05:18 AM
Default LS-carb or fuel injected?????
I am toying with the idea of putting a carb on an LS3. I want to keep some old style look of the carb on my 68 Camaro but don't want to loose any performance from the LS3 either. Any suggestions?
Old 12-15-2013, 05:50 AM
71RS/SS396's Avatar
If you like the old school look. Why not go with a carb intake and one of the aftermarket efi set-ups like Fast, MSD, Holley....etc? Then you'll have the best of both worlds.
Old 12-15-2013, 05:57 AM
I thought about that till I saw the price,not sure if I want to spend that much for an EFI setup.
Old 12-15-2013, 06:19 AM
71RS/SS396's Avatar
I guess it really boils down to what's more important the looks or the performance. While the peak power is really not any different as Greg said, the performance throughout the rpm range is far better with efi. Carbs can only be maximized in a few areas of the rpm range and are only close everywhere else. The fuel around today is not formulated for a carb, there's no anti boiling agents anymore so vapor lock/fuel boiling is a bigger problem than it used to be with a carb.
Old 12-15-2013, 07:00 AM
EFI is the ONLY way to go --- for all around performance and drivability….. but it IS expensive to convert… so I get it when people just want to stick with a simple carb and distributor they have. But if you can swing it - EFI all the way.
I have the 8 stack IR set up on my '32 -- and also had it on my '56 Nomad - you could not have started these cars for months… (on battery tenders!) and go out and just reach through the window and turn the ignition and bam! They start up and idle immediately. Can't do that with a carb…
But EFI is far more costly than just switching an intake manifold. The benefits are many… and worth every penny… but they are far more complicated and costly. The new self tune systems out there are pretty straight forward installations and run beautifully and need no dyno time. So if it's just a street car - and you're not trying to get the last .001 at the drag strip - that's the way I'd lean <no pun intended -- LOL>
Old 12-15-2013, 07:33 AM
71RS/SS396's Avatar
Greg, the cost really depends on if the Op has the factory efi LS intake and throttle body, if he does then there's really no cost savings converting to a carb. The LS carb conversion kit with the intake and igntion box is $700+ and a decent carb will cost $400-$500 which adds up to the same price it would cost to buy the ecu, harness, and pedal from someone like Speartech. Now it won't give you the old school look but to me the overall performance is worth the looks.
Old 12-16-2013, 01:31 AM
The way I see it, if you gonna do an LS and have the intake go all the way with it. A PCM program, Walbro pump and a C5 regulator to me is cheaper than a carb ,fuel pump and ignition controller. If your getting a long block with no PCM, Harness or intake then yeah, its the easy route.
Old 12-15-2013, 07:01 AM
hifi875's Avatar
hifi875 hifi875 is offline
After running a carb on my ls for 3 yrs I switched to the Holley terminator. Really does a good job!!!
Old 12-15-2013, 07:10 AM
WTF -- It's XMAS --- get all your friends and family to chip in and get you this for your carbureted intake manifold…
http://www.fuelairspark.com/fas/ez-e...-pump-kithtml/
Old 12-15-2013, 05:58 AM
It's a proven fact that you don't loose or gain performance between carb or EFI
You gain a lot of other good things going with EFI…
If you want to do it on a budget and just get it done -- go with a carb and the controller…
Once you have that intake manifold etc - you can then switch to a throttle body EFI (a wet system) if you want to down the road.
