Old 01-30-2014, 01:00 PM
130fe 130fe is offline
Default DSE wiper with AAW harness?
I am in the middle of installing a new AAW classic update harness in my car. I was wondering if anyone has integrated the DSE wiper wiring into the stock pins in the AAW engine and dash harnesses. I saw it done on one of the a Red 69 Speedtech camaro I saw at a local car show but the owner wasn't around. I know the DSE wiring has a 30 amp fuse due while the stock stuff is a 15 amp one. Just trying to find ways to clean up the installation. Any help would be appreciated. Thanks!
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 01-30-2014, 10:12 PM
I removed wire in the AAW kit to the bulkhead then wired the DSE pig tail to the engine side and to the switch side. Then swapped the fuse to 30 amp. Makes a nice clean install.
Old 01-31-2014, 04:58 AM
Thumbs up
Thanks Vince, thats what I was wanting to do.
Chris
1968 Camaro SS
LS3/T56
Old 02-14-2014, 07:38 PM
67RSRAG's Avatar
67RSRAG 67RSRAG is offline
Hey Vince any more detail on how you did this?
Old 02-16-2014, 01:09 AM
The first step would be to find out how much length you need to reach the wiper connector.
Cut the DSE harness to the appropriate length.
One side will be on the engine side of the bulk head the other will be on the interior side. Using the extra blade and slot connectors supplied in the AAW kit they plug right in..
Old 02-16-2014, 01:11 AM
Next is to remove the DSE suppled fuse holder and wire. I cut it a few inches from the splice. yellow to the motor, yellow to the power feed and orange to the relay.
The section that remains from the yellow DSE harness will splice into the fused AAW wiper circuit.
Trace the fuse, flipped over, one side of the fuse circuit will be a 10 gauge pink ignition feed and the other will be the wiper supply. Splice or hook up to the wiper supply pin.
