Old 01-16-2011, 10:03 PM
ttchevelle's Avatar
ttchevelle ttchevelle is offline
Angry Two Walbro 255 Lph Pumps
Just got back from the dyno for my first pull. Fuel pressure fell to 33 psi @
4848rpm twin turbo set up made 447 rwhp with 15 psi boost. AFR went to
12.2. Realized that only one of my fuel pumps are working. I found the fuse blown
and the second pump is shorted. Is this comon for a walbro 255 pump?
1965 chevelle ls1 twin turbo/th400/currie 9 inch
Old 01-17-2011, 12:03 AM
camcojb camcojb is online now
In my experience the Walbro's are good pumps, no issues.
Old 01-17-2011, 05:00 PM
Hope you're running them on relays....
Ran a walbro for 6 or 7 years with zero issues. Putting a Walbro 255 in tank in the '32 Ford I'm doing EFI as we speak.
Old 01-17-2011, 05:56 PM
CarlC CarlC is offline
What's your fuel pressure at full boost?
http:www.vaporworx.com
Old 01-18-2011, 06:32 AM
ttchevelle's Avatar
33 psi. I found out that one of my pumps had failed after the fact. With only one pump we made 447 rwhp with the potential of alot more with two.
Old 01-18-2011, 07:25 PM
64duece 64duece is offline
We've had good luck with them aswell. Have you considered adding a fuel pressure saftey switch/transducer? We run multi-pump applications very often and always try to have something for safety just in case.....
Dennis
Moore Racecraft
Old 02-28-2014, 12:08 PM
gnx7's Avatar
gnx7 gnx7 is offline
Since your fuel pressure fell make sure your filters are the proper ones and that you don't have a carb style somehow accidentally sent out. Also make sure they aren't knockoffs. Not sure how you tell. Dedicated quality (Bosch) relays or similar only.
Are you on pump gas or e85?
I'm going to run 2 of the Walbro 400/450lph e85 pumps for mine. Should support 1000rwhp+ on e85 with -8AN feed line.
Old 04-04-2014, 09:32 AM
wedged wedged is offline
so the af was 12:1 ? what was it normally or what should it be at WOT ?
12:1 should be fine for NA , but i guess boost is a little different ?
Old 04-04-2014, 10:26 AM
mitch_04 mitch_04 is offline
The OP hasn't been on in 2 years, I wouldn't get my hopes up about getting answers.
Old 04-05-2014, 06:57 AM
SuperB70's Avatar
SuperB70 SuperB70 is offline
I dont know is it same in US but there (Europe) Bosch gives only 500 hours warranty to they pump when using E-85.
Water and E-85 is really bad to non anodised aluminium.
, Juhani
