Old 05-17-2006, 12:17 PM
Supercharged 86 Supercharged 86 is offline
Default Weiand 142/780 Holley/LS front end/th350/headers *PICS*
Blower --> It was bright powder coated (basically like a polished finish in powdercoating). It is for the pre 1986 SBC with long water pump. Included is the blower with cable adjuster, intake, and the belt and pulleys to make 7-10lbs boost. Some coolent leaked on the intake and the blower isn't perfect either, but it may be able to be cleaned and they will look about the same as in the picture when installed even if not cleaned. Rotors look to be in great condition, but it would be a good idea to gap them properly once again to be sure while it's out of the car anyway. I have the feeler gauges and instructions. The blower gasket I also have in new condition (not supposed to use sealer on them). It was always torqued properly as well. They take very little torque so as to not warp the blower case. PM, reply, or email at [email protected] if interested. $1400 shipped to lower 48.
Asking $200 + shipping on carb. 780 holley. Vac secondaries and elec choke. Was told it ran fine on big block GTO.
$200 + shipping on Monte front end. I was going to put this on a Monte, but ended up not getting the car. Should have pics up later.
$150 on 1 3/4" headers into 3.5" collectors. Bought from SpeedwayMotors and sold engine. Ports have been cleared up a bit and they'll run nicely, but not perfectly CNCed or anything. Never used
th350 trans $500 with 4000 stall converter, TCI shift kit, drain plug oil pan. I need the room and money. Pick up in South Jersey.
Old 05-22-2006, 05:53 PM
pretty please?
Old 05-24-2006, 05:40 PM
headers are sold
Old 05-26-2006, 01:08 PM
ttt ttt
