Old 06-11-2014, 10:57 AM
6carmello8 6carmello8 is offline
Default LQ9 swap question (ls1 intake/belt system)
After the 6 months of run arounds and basically the shop I had my car worked on going out of business, I had to pull the car out and bring it to my friend who is a mechanic and that works on performance Audi's and GTR's...
So basically, I have been doing a ton of research on my own.
The car is almost done but have a few questions.
If I buy a complete Ls1 manifold (rails, injectors, TB (DBW), can I use the injectors from them or should I swap them out with the stock Lq9's?
Also, do I have to run the car style accessory drive if I run there brackets?
http://dirtydingo.com/store/popup_im...D=1394&image=4
I have an complete LS1 front accessory drive but I figure the labor in swapping it out would be more expensive then just buying these brackets...
Any info would help and thanks in advance.
Old 06-12-2014, 08:48 AM
oldgoat's Avatar
oldgoat oldgoat is offline
The intake swap has been documented many times at www.ls1tech.com . You can use the F-body FEAD but it will require a water pump change. The injector compatibility is more a matter of wiring harness connectors than anything else. I take it that the car is a Camaro? Do you have the correct oil pan? The truck pan won't work since the sump is too deep.
Old 06-12-2014, 09:21 AM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
+1 on you can use any injector just make sure the connector is right, I have to mod my fuel rail to run truck injectors. Swapping the front drive to ls is really easy, looks better, and gives you more clearance. Ls1 intake should work with truck front drive if i remember correctly.
Alabama
1969 Camaro
1978 Camaro
Old 06-12-2014, 10:29 AM
Yes it has been documented but not in this case...I'm not trying to be offensive in anyway, but I wrote the swap is almost done as in the Lq9 and t56 is already in the car so yes, the oil pan is already on and in. I know that that the truck FEAD doesn't work because the alt/bracket is in the way of the car style manifold/TB that's why I mentioned about buying the bracket I attached because it might be an easier alternative then taking out the truck FEAD and swapping it with the car stlye FEAD that I already have. The car is a Camaro. So the question was keep truck FEAD buy brackets or swap with car style FEAD....
I figured you could use any injector but would this require a retune? Truck FEAD drive doesn't work with the car style manifolds not to mention it's too tall to clear the hood. It's good to know that it look better thanks!
Any other tips guys that you guys can give me?
Old 06-12-2014, 10:49 AM
CamaroMike's Avatar
Its highly recommended to get a proper dyno/retune unless you have the factory exhaust manifolds and airbox.
I just did the same thing, its very pricey. All the small stuff adds up quick. Took me $5k to do my ls swap from a truck engine and I got good deals on all my parts. If you switch to a ls1 front drive you have to do the balancer as well, the truck balancer sticks out too far.
What year camaro is it going in?
Alabama
1969 Camaro
1978 Camaro
Old 06-12-2014, 11:12 AM
It's a 1968 Camaro. I have the ls swap 1/7/8" Dynatech headers and will have an Ls1 manifold and an filter in fornt like most...so I probably should get a tune. I didn't know that the balancer sticks out too far but I have one from an Ls1 so thank god.
