Old 06-14-2014, 05:58 AM
SSLance's Avatar
SSLance SSLance is offline
Default Vibration issue, tire related?
I've been slowly but surely over the years chasing down every single little vibration issue on my car to make it as smooth as possible at highway speeds and I've got it pretty dern good now...but I'm still fighting one thing and I'm stumped over what it can be.
So I'm posting this question to see if anyone else has an issue like this and if it is common or unusual in my case.
When I take my car out of the garage and go down the highway, initially it'll have the typical flat spot feel from the tires sitting in one spot. It generally only takes about 3 or 4 miles of highway time for that to go away though...then the car is super smooth wherever I go with it. There is virtually no vibration at any speed when the car starts out cold like that.
But say I drive it to work, and it sits in the sun all day...on the trip home it'll have a shudder that feels like it's coming from all 4 tires between 60 and 70 mph. I can drive through it, or raising or lowering the speed just a bit will make it come or go, but it'll settle back in and not go away. It's not bad enough to make the rear view mirror unusable, but it is certainly noticeable. I first started noticing it on the way home from an autocross event, it scared me pretty good the first time because I thought I broke something in the rear end. But I drove the car again a couple of days later and she was smooth as silk again. The shudder only happens after the car has sat outside in the heat for a while after the tires have been heated up.
It is definitely tire or drivetrain related, pushing the clutch in and coasting doesn't change the vibration at all. and I feel it in the steering wheel and my butt, so it feels like it's comes from the front and the rear. Is this just a trait of 200 tread wear performance tires? Do the rest of you that run a high end sticky street tire have this happen as well?
All of my wheel bearings are fresh and tight, the Falken 615Ks have about 750 miles or so on them, everything else on the suspension is tight and fresh and even the rear axle and clutch have all been freshly rebuilt with no change in this attribute...it almost HAS to be the tires themselves right?
And I'm okay with it...as long as I know that's what it is. If there is something I can do to help it I'm in, or I can just deal with it.
Lance
Old 06-14-2014, 06:47 AM
Sieg's Avatar
Sieg Sieg is offline
The last two sets of Bridgestone tires on my Tundra pickup will flat spot from sitting. It takes about 10 miles for them to make themselves round again.
Haven't noticed the issue with the NT05's on the Camaro.
Old 06-14-2014, 07:54 AM
It's been some time since I had Falkens on my BMW but I was less than impressed with them from a drivability standpoint.
Old 06-14-2014, 11:45 AM
SSLance's Avatar
I should add, if I leave my car in the garage at work, and drive home that evening, it's fine. It only happens when the car has been sitting out in the sun\heat for a while. And it does not go away until the car has been parked back inside and cooled off.
I guess I should start checking the tire pressures and tracking them to see if they change drastically before or after this occurs.
I know i'll bleed 4-6 PSI out of them during an autocross event so they are low after it sits for a while before the drive home. but once home I fill them back up and they stay like that until the next race.
I LOVE the way this car handles on these tires, they really are amazing. And if this is just a trait they have, I'll deal with it. I don't think it's damaging or anything like that. Just trying to get the ride as Rolls Roycey as I can get it.
Lance
Old 06-14-2014, 01:18 PM
Track Junky's Avatar
First off, before I let my car sit I always over inflate the tire a bit so that they don't flat spot. If your vibration is wheel balance related, I dont know about auto cross, but under road race conditions the tire will slip around the wheel causing an imbalance.
Gaetano Cosentino
Old 06-14-2014, 01:36 PM
SSLance's Avatar
Just curious, about how much extra air do you put in them when you let it sit for a while?
I've had tires that flat spot when sitting before and these do that as well, but that goes away very quickly. What I'm experiencing and describing now happens after it sits outside in the sun for a while and does NOT go away after driving it.
Lance
