Old 05-28-2006, 08:36 PM
Datsbad's Avatar
Datsbad Datsbad is offline
Default Trouble with AAW wiring??
problem solved , I am a dumbass
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 05-28-2006, 10:53 PM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
Have you checked that everything is grounded (to earth) properly?
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 05-28-2006, 11:11 PM
Sparky's Avatar
Sparky Sparky is offline
Is this only with the Right Turn Signal or does the Left Turn Signal have the same effect? It would only stand to reason that if the Headlights flash with the Right Turn Signal that they will flash with the Emergency Flashers.
The Front Turn Signal/Run Lamp is supplied Ground through the base of the Lamp that bolts to the Valance, but if Ground were an issue, it would travel through the Run Lamp Circuit and find Ground, which would cause the Run Lamps to flash and not the Headlights
The Headlight Circuit is isolated from the Run Lamp and Turn Signal Circuits, with that being said do you have a DVOM? (Digital Ohm Volt Meter)
I would check the resistance between the Right Turn Signal Wire (Dk Blue) and the Headlight Wires (Tan -Lo Beam and Lt. Green – Hi Beam). Hint: if the High beam indicator isn’t flashing while the Right Turn Signal is on it is probably the Low Beam. If the resistance is low then the two circuits are somehow shorted together. They could be pinched, melted, pinned wrong at the cowl connector, etc. Inspecting the front headlight harness carefully might lead you to where the trouble spot might be. I do have Electrical Schematic information on the 69 Camaro if you need to know the correct pin assignment of the cowl connector.
I hope this helps and please feel free to contact me, I will do my best to help you.
Sparky
Wires & Pliers
Michael Browne
8415 McClements Rd
Brighton, MI. 48114
810-229-9688
Old 05-29-2006, 04:26 AM
ProTouring442's Avatar
Very frustrating I'm sure! It looks to me to be a ground problem. Go through with jumpers and grouns each componant, if this elimintates your problem, start removing them one at a time, putting it back until the problem show back up. Once it does, Bingo! One caveat, old light sockets sometimes build up a bit of rust between the body and the socket. You may need to replace a socket if this is the case. You will need to ground EVERYTHING in the circuit you turn on, grounds can backtrace through quite a circuitous path!
Good Luck!
Bill
Old 05-29-2006, 09:34 AM
Datsbad's Avatar
well guys thanks for the help . fortunately I found the problem , Turned out it was my fault. Sorry for the waste of time!
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 05-29-2006, 10:22 AM
Out of pure curiosity, what did you do wrong?
Jan
Jan Suhr
Stockholm, Sweden
Old 05-29-2006, 11:02 AM
Datsbad's Avatar
Jan
well the marquez dash insert does not have provisions for the turn signal indicators. so the wires for them i had tied up , apparently some bare wire was sticking out and touching another wire.
It all works fine now
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
