Old 07-23-2014, 04:15 PM
Chassisworks Chassisworks is offline
Supporting Vendor
Default New Product Release - Chassisworks’ gStreet Billet-Aluminum Spindle System
Designed as the ultimate upgrade for top tier pro-touring performance, the new gStreet spindle provides vastly improved geometry, bearings, and brakes for all Chassisworks’ bolt-on front clips.
Use of this spindle requires Chassisworks new gStreet Wide-Track control arms which provide more gradual geometry changes throughout suspension travel for more direct tire feedback and more linear response to steering and braking inputs under various dynamic conditions.
Specific geometry changes include vastly reduced scrub radius, improved camber gain, and increased caster (8.5 degrees at center of adjustment) without altering the wheelbase. The lightweight upright houses a heavy-duty, sealed unit bearing that is both larger in diameter and considerably more reliable than the commonly used Corvette components.
Completing the gStreet system is the large diameter brake package built around Wilwood Engineering’s race-bred Aero6, 6-piston, radial-mount caliper with 14” or 15” vented rotors
Check out this link for a massive amount of technical info and more pictures! https://www.cachassisworks.com/Attac...XXX_DS_WEB.pdf
Old 07-23-2014, 05:52 PM
MoparCar MoparCar is offline
Very nice. This will also work with your universal weld in crossmember also correct? Same track width as your normal spindle?
Old 07-23-2014, 05:58 PM
Ron Sutton's Avatar
That is nice! Chris Alston has always designed top notch stuff, but he may have outdone himself here.
This is no warmed over C6 spindle copy. This is a scratch built spindle with all the tricks. I got a sneak peek at the bearing design & size. They're super strong.
Ron Sutton Race Technology
Old 07-24-2014, 06:06 AM
Payton King's Avatar
Very nice!
Is this a direct replacement for a C5/C6 upright?
Will the hub/bearing pack bolt into a stock C5/C6 upright?
Old 07-24-2014, 10:46 AM
I think you posted the ladies menu cause I don't see a price.
Old 07-24-2014, 01:44 PM
Supporting Vendor
Yes, it will also work with the crossmember systems; we make them in 15 different widths with adjusted geometry. The track width is slightly wider than what the corresponding crossmember width would normally dictate. This helps in the pursuit of greatly improved geometry and handling.
Thanks Ron! The first ones have already shipped to some very excited customers.
Originally Posted by Payton King View Post
Very nice!
Is this a direct replacement for a C5/C6 upright? Will the hub/bearing pack bolt into a stock C5/C6 upright?
This version is not a Corvette replacement; this is a completely proprietary piece. It fits all our bolt-on front clips and a-arm crossmembers. We are using a larger bearing with higher load capacity that does not fit the C5/C6 upright.
We are considering a version of this upright that will fit Corvettes. No ETA is available for the Corvette version.
Pricing for individual components is up on the website HERE. It does not reflect the package pricing when purchasing the whole kit 'n' kaboodle.
Old 07-24-2014, 07:50 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Is this a sealed bearing unit? What does this upright/bearing unit weigh?
Thanks, Jay
