Old 07-12-2016, 03:03 PM
MAK567's Avatar
MAK567 MAK567 is offline
Default Ats tall spindle and Ridetech Strong Arms
Can someone tell me if the Ats spindle will work with Speedtechs control arms?Aplication is for a 70 Chevelle.
Old 07-12-2016, 04:18 PM
Shiner's Avatar
Shiner Shiner is offline
I'm using the ride tech drop spindles which are tall and similar to the ATS.
1970 Chevelle SS
408 Forged LSX, LSA Blower, 4L80E, Ridetech HQ, Baer Brakes, Weld S71b
1997 Dodge Viper GTS
Heads, Cam, Bolt On's, BBS Wheels, Moton Suspension
Old 07-13-2016, 06:49 AM
Blake Foster's Avatar
Actually there is almost NOTHING similar between the Ridetech drop spindle and the ATS Spindle.
Ridetech
2" drop
Steering arm not relocated
uses stock steering arm
uses taper bearings
forged steel
ATS
1" drop (generally you don't need 2" of drop to get the ride height )
Steering arm relocated
available custom steering arm to help with bump and ackerman
uses Corvette C7 SKF bearing pack
Forged 7075 Aluminum (less weight)
they do both fit though
Blake Foster
www.speedtechperformance.com
Old 07-13-2016, 08:12 AM
MAK567's Avatar
The reason for the Ats spindle is i am using zo6 brakes and dont want to have all the extra brackets and hubs associated with putting the zo6 brakes on to ridetech spindle.I just want a clean install so if the spindle works just as well on ridetech arms then i would rather do that.
Old 07-13-2016, 06:41 AM
You have asked 2 questions Ridetech arms or Speedtech arms? I will ask if your considering the ATS Spindle why would you not purchase the Speedtech arms as well?
this car has the Speedtech A body Track time package plus the Chicane coilo over conversion and ATS Spindles. It has been doing VERY well at GoodGuys and Optima. it has 315 all around no mini tub modified inner front frender wells and outer lips but
http://www.speedtechperformance.com/...rod/prd395.htm
Blake Foster
