Old 11-23-2014, 08:57 PM
Docwood Docwood is offline
Default Carbs
Hi, I need advice/suggestions on a carb for my 69 camaro. I currently have a 350 with an old b&m 162 blower fed by dual webers (40s). Needless to say, its a maintenance nightmare. I'm thinking of changing it to a holley 80572s. I believe it's made for blowers. I dynoed at 300 rwhp with an old doug nash 4+1. The manual recommends a 4150 but only use single pump 750. Any thoughts advice on other carbs?
Old 11-24-2014, 05:51 AM
Rod P's Avatar
Rod P Rod P is offline
?? why wouldn't you use the FACTORY recommended parts??
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 11-24-2014, 12:28 PM
The factory also recommended the use of the dual webers, but it's not working out too well. Was just looking into other options. I am still looking into the holley 80527s which is a 4150. Have you or anyone you know used this carb? Any issues with this particular carb? Thanks for the feedback!
