Old 10-21-2014, 07:47 AM
SSLance's Avatar
SSLance SSLance is offline
Default Convert to floater or replace my axle housing?
As I'm currently replacing my 4th axle bearing so far this season so I'm now starting to look for options to upgrade from my Big Bearing Ford axle ends to something with a tapered bearing or full floater design.
I'm currently running a 9" housing with 31 spline axles, the Torino style big bearings and a Ford Explorer rear disc brake setup and I like everything about it except the bearings just can't seem to handle the side loads I'm putting on them now.
I've searched around and found a few threads on full floaters but most refer to buying complete custom ordered housings. I guess that is an option but I'd like to see if there is a way to fab floater ends onto my existing housing as another option.
My main concerns are packaging and brakes. I don't have a frame notch and I don't want to buy new rear rims with a different offset unless it's absolutely necessary. It really doesn't cost that much to keep replacing my existing bearings so spending $5,000 or so for a complete package wheels to pinion doesn't make sense. But if there were ends available that I could graft onto my housing and make a sensible brake package work with them...I'd like to explore the idea.
Am I completely off base here or is this something that has been accomplished before?
Lance
